Woooooooaaahhh !!! My precious ![]()
All good so you get allmost all !?!
Yes for your elec enclosure you can print it, but it work really fine to make your’s hand made in époxy/fiberglass !
He got a good tutorial that we all follow
: HERE and some more here ![]()
- OKP is a magician and has incredible skill and patience.
:lol: That is true, OKP MASTER still win !!
If I read weel your step is good,
2 - resin and hardener mix and one layer of fiberglass/carbone exactly (you can insert your fixing hole between 2 layers of fibreglass/carbone but put fiberglass inside to separe carbone from electronic)
3 - you could make step 2 in 2 times, 1th the part and then see how all fit, you can adjuste them cut you fibreglass enclosure to adjust and then reput fiberglass and carbone to re-enforce all !
- And then sand down, paint and you can reput a fine layer of epoxy to protect your paint/graphism 2
You can easly do it, I saw that you knew very well tinker ! This is a new experience and can be usefull for your drone or everything esle if you want to add a light body of carbone on it … And your enclosure gonna have the same concave of your deck ! And the mini space under your deck
Its a good deal I think.
otherwise I have « VENDS boitiers batterie Alien ABS et fibre diy (#1) »
good continuation ![]()
