Top, on fait comme ça
Enfin comme tu veux surtout !
Super intéressant tout ces tests à venir aussi (traction en single), avec ton niveau de ride en plus, ça peut que donner de bon retours d’infos !
Official Apologize for Cancel Dual FSESC6.6 Project
Due to MP difficulty for tower design PCBA and the pre-sale effect is not so good. We’ve decided to cancel Dual FSESC6.6 Project. Sincerely apologize to all of pre-ordered customers!
Here is our compensation solution for you to choose:
A. Replace our new upgraded dual FSESC6.6 180A to you, but the shipping date is postponed to 24th August.
B. Send you 2pcs FSESC6.6 with aluminum case and 1pc Can bus cable and 1pc remote controller. Total value $411.2.
C. Replace our new dual FSESC4.12 100A(MSRP: $159),and refund the rest payment($141). Or replace 2pcs FSESC4.12 100A . The shipping date is 16th/August
D. Full payment refund
Our member will contact you!
Sincerely,
Flipsky Team
Sorry, the above one is missing some words…
Sincerely,
Flipsky Team
Hi, eh, it’s me again. Sorry about the delay of our dual FSESC6.6. In order to retain builders who prefer a dual setup, we have launched our dual FSESC4.12. ![]()
Please take a look at its specs and pics:
Advanced Features:
1.Dual ESC can reach 100A big current, give your board strong power
2.One PCBA board integrate two FSESC4.12 ’s function by internal CAN BUS circuit connection.
3.The mater and slave board connection can be switched On/Off
4.Delicate design in details for high quality assurance: add Anti-vibration silicon pad for screw heatsink and heat-transfer pad
5.Preserve Bluetooth module and RF module connections for both master and slave board
6.Super small size and light weight with heatsink: 79.6mm65mm18.8mm(LWH), wight: 147g
Specs:
Hardware:V4.12
Firmware: latest version
Current:50A continuous/single, 100A continuous/dual , burst 150A/single, burst 300A/dual
Voltage: 8V-60V (Cells: 3-13S LiPo)
BEC: 5V@1.5A
BEC type: Internal driver support
Timing: Software calibration
Cutoff Voltage: Programmable
Frequency: PWM input
Governor: No
Programming card: No
Reverse: No
Pics:
Looks super cool ! It been 2 or 3 year we wait a product like that ! Hope it will handle it as good as a standard single one or even more
So 13s at 50Amps, look cool enought
Can’t wait to get our Mr P lookback on it !
Thanks for sharing
Oh, forgot to post its link:
https://flipsky.net/collections/new-acc … c4-12-100a
Thank you for your quick reply!
And as I’m kind of new here, so is Mr.P means Mr.Pimousse?
Of course that’s it !
Mr. P = Mr. Pimousse
Great, thanks!
Easy guys, I’m not Vedder ! :lol:
From what I can see, I don’t find any issue other than the USB port orientation.
It constraints user to have a hole on the side of the enclosure to access it.
Could be interesting in some builds configuration, can be an issue in others. It depends.
No, you’re not Vedder ! You are our Pimousse !! hahaha sorry, come back to FLISKY technologie…
Did you report better thermal result compared with standard double vesc 4.12 ?
En tous cas les gars, j’aime ce que je vois, ça me rappel le dualesc 30A que j’avais avec les hubs moteurs, mais en version vesc quoi
ça à l’air cool si c’est le cas, surtout si c’était aussi efficace thermiquement qu’une fox, se serait carrément bonard ! D’ailleurs la Unity ? des news ?
Le FOCBOX Unity est dans les starting blocks apparemment :
https://www.enertionboards.com/raptor-a … troller-1/
Attention, là on parle plus de VESC.
Un seul MCU pour 2 moteurs, donc firmware différent (après ils ont peut-être pompé des morceaux de codes à droite, à gauche, on le saura probablement jamais).
ouah, merci Mr P, c’est vraiment esthétiquement très attrayant en tous cas
supers beaux visuels !
L’ingénieur dit qu’il va maintenir une version de VESC Tool pour la unity en parallèle avec son propre outil simplifié. Il présentait plutôt la unity comme un fork du VESC. Il avait l’air de dire qu’il a rajouté des bouts de code à droite et a gauche à partir du code VESC. Il disait que s’il avait un peu d’aide et le soutient de Vedder il pourrait parfaitement intégrer toutes ses modifs dans la main branch mais que c’était trop de boulot pour lui tout seul.
Ce qui serait bien à intégrer dans la main branch c’est son code pour la détection du moteur automatique juste en faisant un tour de roue à la main.
Wooww j’ai raté un épisode là !
Déjà techniquement, même en config 2 shunts, il faudrait 4 ADC injectés pour ça.
Il a donc dû passer sur un modèle supérieur de STM32 = du code à bouger.
La détection en faisant tourner la roue à la main, je comprends pas non plus. Peut-être que tu parles des sensors ? La ça pourrait marcher.
Par contre, intégrer qon HW dans la main branch, c’est juste inconcevable pour moi, trop de truc à modifier spécifique à son design et ça, c’est une philosophie que Vedder accroche pas trop…
Check leur video unity in depth ils parlent de tout ca longuement, le reste c’est dans ce thread, l’ingénieur deodand post régulièrement dedans.
Pour la détection moteur avec un tour de roue c’est possible qu’il faille obligatoirement des sensors, je ne crois pas que ca soit mentionné dans la video mais ca fait bien 2 semaines que je l’ai vu. Même si c’est le cas je trouve ca cool quand même.
PS sorry to parasite the flipsky thread, maybe this should be moved to its own thread.
PS 2 tant qu’on parle de la unity y a un group buy possible pour 175€ hors tva et frais de douane qui se prépare j’ai vu.
En vrai tout le sujet devrait être déplacé car on est dans la section R2R - les marques. Alors que là on est en plein dans le DIY. Mais j’ai pas trouvé de section du style DIY - les marques.
En effet la FB Unity mérite son propre topic si c’est pas déjà fait.
Another new product–Mini FSECS4.20! ![]()
Basically the same specs as the standard one:
Hardware:V4.20
Firmware: Latest Version
Amps: 50A continuous / 150A peak
Cells: 3-13S LiPo
Voltage: 8V-60V
BEC: 5V@1.5A
Governor: No
Weight: 76g
PCB Size: 39x46x17.4mm
Size:68 x39x19mm(Include Heatsink)
Reverse: Yes
You may also learn the upgrade of this mini esc from the below website:
https://flipsky.net/collections/new-arr … oter-ebike
Just for my curiosity, as you are kicking out a lot of new designs, what are the tests performed of these products before putting them into production and selling ?
BTW, congrats for this design. The smaller, the better !
