TorqueBoards 29″ Speedster
on dirait que Dexer se lance dans des boards complète
http://diyelectricskateboard.com/diy-el … speedster/
Don’t underestimate this LITTLE MONSTER. This 29″ Electric Skateboard is by far the best in it’s class with tech specs that rock your socks.
This isn’t your run of the mill electric skateboard. It isn’t mass produced and they are built specifically for YOU our customer.
The TorqueBoards 29″ Mini is our most lightweight and compact electric skateboard.
Unlike, other companies our products give you more BANG for your BUCK. By using our DIY Electric Skateboard components, you can upgrade to a dual motor setup at anytime or replace a part for an affordable price. You can customize your gearing ratios for more torque or more speed.
The TorqueBoards 29 Mini was designed for reliable and quick transportation while maximizing portability. We’ve specifically designed our boards around our high performance parts for a durable and reliable setup.
Perfect for boostin’ and cruising around city streets, getting to your college class, riding back to your dorm room, cruising the beach boardwalk or just plain ole’ enjoying the breeze.
Check out our technical specifications.
Technical Specs “29 Mini”
  • Top Speed: 20-25 mph / 32-40 kph
  • Power: 1500 watts
  • Battery Range: 6-8 miles / 9-12 km
  • Board Weight: 10 lbs
  • Max Rider Capacity: 180 lbs
  • Braking System: Regenerative Braking
  • Throttle Control: Trigger Throttle
  • Connectivity: 2.4ghz
  • Wheels: 83mm (76A)
  • Charge Time: 1-2 hours (45 minutes w/ fast charger)
  • Batteries: 7S2P 6000mah
  • Deck Material: 8ply Canadian Maple w/ 1ply Carbon Fiber
  • Deck Dimensions: 29″
