My esc blew up due some water intake, i’m searching for a new one,
also, any change the motors got damaged due the esc shortage?
Thanks !
Thanks !
Think about a fuse for the next time!
Hi Seb !
With esc are you looking for ?
I got 2 - Alien (120A 3-12S Jet ESC HV) to put together with Y wiring for a dual esc :
It has 5 mega mega capacitors of 63v 470mf, 5.5mm connectors direct soldered on the PCB, battery spark suppression wire, heat sink, powerful Mosfet, USB link to program it.
Specs:
Size: 120 x 60 x 20 – Weight: 200g
Battery voltage from 3S to 12S.
Simply set function value by Pro-Box, by PC via USB kits or by trasmitter.
Two way communication while connecting it with computer.
Firmware will be upgraded automatically.
LVC
Timing settings may be adjusted (0°- 30°)per degree to suit the motor type
3 types of throttle curve
3 types of acceleration control.
Motor rotation programmable.
Auto cut off power within 3 seconds in case of signal loss.
Function Value:
BATTERY TYPE:Ni-XX、Li-XX
NUMBER OF CELLS: Auto,2,3…
LVC: programmable
PWM frequency: 8 – 16 – 32
FORWARD POINT:Auto、fixed 1.0mS、fixed 1.1mS、fixed 1.2mS、fixed 1.3mS、fixed 1.4mS, fixed 1.5mS
REVERSE POINT:Auto、fixed 1.7mS、fixed 1.8mS、fixed 1.9mS、fixed 2.0mS
MOTOR POLE N°:motor poles number, 2-4, 6-10, 12-14 (HELI ONLY)
THROTTLE CURVER: Logarithmical、linear、Exponential
ACCELERATION: Soft / Medium / Hard
TIMING MONITOR:On/Off
DELAY TIME FORWARD TO REVERSE: MS (CAR/BOAT ONLY)
PWM LIMIT: 0N/OFF (CAR/BOAT)
MODE HELI: CONSTANT RPM/NORMAL (GOVERNOR MODE)
CURRENT LIMIT: AMP (CAR ONLY)
ABS BRAKING: % (CAR ONLY)
MOTOR TIMING DEGREES: 0°、1°、2°、3°、4°……30°
ROTATION:Left/Right
REVERSE: ON/OFF (CAR/BOAT ONLY)
“Y” configuration :
The water was all over the ESC, a fuse would not do much help…
I won’t need a ESC for now, Bruno from alienpowered.com is gonna take a look at it, talking about great service !!
I’m not sure that will be the only damage though, Currently my BECs are weird in voltage output,
Two alienpowered BECs (one is outputting 2.5v and the other one nothing)
The red led is on though on the BECs… could be they have to be wired that way, not sure, i bought the board completely assembled from Richard at aliendrivesystems…
Also i could have sworn there was a little bit of smoke coming out of one motor. Not sure what the damage is over there.
I turned it off at a time range of a few seconds after my failure and then walked the walk of shame back home.
ho sure he will find the solution to your problem
I sure hope so, i feel like the guy who just bought a sportscar and crashed it the minute he left the garage…
This topic can be closed if needed.
done !
