12S Max - 120A - Idéal pour nos esk8 en single motor
Prix neuf AlienPowerSystem (hors fdp) : 90.50€
Prix demandé : 75 € !
Connecteurs 5.5mm bullets, pré-programmés (basic APS pour esk8)
Connectez les 2 ESC en « Y » sur une batterie donc DualRear (2WD) ! Jusqu’à 12S en 6374 !
UBEC + câble de programmation fournis
prêt à l’emploi
It has 5 mega mega capacitors of 63v 470mf, 5.5mm connectors direct soldered on the PCB, battery spark suppression wire, heat sink, powerful Mosfet, USB link to program it.
Specs:
Size: 120 x 60 x 20 – Weight: 200g
Battery voltage from 3S to 12S.
Simply set function value by Pro-Box, by PC via USB kits or by trasmitter.
Two way communication while connecting it with computer.
Firmware will be upgraded automatically.
LVC
Timing settings may be adjusted (0°- 30°)per degree to suit the motor type
3 types of throttle curve
3 types of acceleration control.
Motor rotation programmable.
Auto cut off power within 3 seconds in case of signal loss.
Function Value:
BATTERY TYPE:Ni-XX、Li-XX
NUMBER OF CELLS: Auto,2,3…
LVC: programmable
PWM frequency: 8 – 16 – 32
FORWARD POINT:Auto、fixed 1.0mS、fixed 1.1mS、fixed 1.2mS、fixed 1.3mS、fixed 1.4mS, fixed 1.5mS
REVERSE POINT:Auto、fixed 1.7mS、fixed 1.8mS、fixed 1.9mS、fixed 2.0mS
MOTOR POLE N°:motor poles number, 2-4, 6-10, 12-14 (HELI ONLY)
THROTTLE CURVER: Logarithmical、linear、Exponential
ACCELERATION: Soft / Medium / Hard
TIMING MONITOR:On/Off
DELAY TIME FORWARD TO REVERSE: MS (CAR/BOAT ONLY)
PWM LIMIT: 0N/OFF (CAR/BOAT)
MODE HELI: CONSTANT RPM/NORMAL (GOVERNOR MODE)
CURRENT LIMIT: AMP (CAR ONLY)
ABS BRAKING: % (CAR ONLY)
MOTOR TIMING DEGREES: 0°、1°、2°、3°、4°……30°
ROTATION:Left/Right
REVERSE: ON/OFF
Enjoy & Bon Ride !
