Alien Power Pack Dual drive 8S 10000mah 25C Lipo
Alien Power Pack Dual drive 8S 10000mah 25C Lipo, ça à l’air pas mal, vivement que le 12S se démocratise dans le milieu, en tous cas c’est intéressant des pack comme ça ! :sunglasses:
Product Description
The new Alien Power Pack is an 8S super flat Lipo battery (only 20mm) designed to be used in DIY Electric Longboard application. The battery has a built in High power BMS 80Amp constant power, with a cut off set on 150Amp. On the battery is available a voltmeter to check the battery status. The Alien Power Pack has a built in power switch circuit to turn on or off the system.
Alien Power Pack is available as Standard or single and dual built in ESC system to be a complete plug and play item. Available in 8S 10000mah setup or 6s 8000mah setup.
Any customization are welcome.
Spec:
SIZE: 400 x 130 x 20 (40 on the ESC end)
WEIGHT: 2250g
MAH: 10000
N° of cells: 8S/1P
Nominal Volt: 29.6
Discharge rate: 25C
Wires: Silicone 10AWG
Battery connectors: NO
Charger: 100-240v Aluminium case 33.6v 5amp fast charger with Led and fan
Charging time: approximately 2.5H
Built in BEC for ESC and optional 5V third accessories
ESC:
Size: 90 x 110 x 20 – Weight: 250g
Internal BEC: YES
Battery voltage from 3S to 12S.
Completely plug and play ESC
The system is powered by a main switch that can activate a single or dual ESC
This will allow the user to choose Single or Dual motor configuration.
Taking advantage of the increased range – a single motor offers or Increased performance including braking and hill climbing that a dual motor will offer.
This battery is a custom made product by APS. All Alien batteries are made by a specialized japanese high power batteries company. The C rate is the real power that the battery can deliver. The warranty covers only factory faults. Every battery is tested before being sent. If there is a fault, the buyer needs to make a claim within 7 days after receipt of the item.
Quelqu’un a des news des futur 6354/6355 d’APS ?! :roll:
à priori ça sort en Janvier; après on sait pas encore de quelle année :smiley:
J’ai rouler en le modèle 8s 35c
C’est vrai que la batterie est super plate et la charge prend 2h30
Sur le papier c’est top
Mais attention j’ai eu des soucis avec
Le pack coupe son alimentation en strappant l’inter
C’est à dire que tu roules et le pack se coupe et donc les moteurs se bloque
et tu finis sur le bitume
J’ai eu 3 coupures
En fin de pack (3,6v un peu haut ) donc tu rentres la planche sou le bras
En passant sur une rigole rapidement, ça a fait une grosse vibration sur la planche et tout s’arrête
Dans une grosse montée à 30 km (et la c’est fatal ) car il y a une sécurité de 50 À
Peu être que mon pack avait un défaut mais en tout cas je ne compte plus utilisé ce type de modèle
